Effect Channels [Tab 8]
The Effect Channels display allows you to override certain effect properties per channel at the cue level.
Effect Channels can be opened in a standalone tab from the Workspace Layout Menu or by using [Tab] & [8].
The following properties can be overridden:
- Rate
- BPM
- Size
The following properties can be overridden for focus effects only:
- Axis
- H Form
- V Form
To add a channel level override, first you will need to be in the Effect Channel display with the effect running.
[2][6]<Effect><1>{Rate}[6][Enter] - to change the rate for just channel 26. With the effect running, the console will default to the running effect number. You may need to select the effect first ([Effect] [n] [Enter]). This will open the effect status display, and you will have access to the effect softkeys.
In the effect status display, an “+” will display by any effect property that has a channel level override.
You can then store these channel overrides in a cue by using [Record] or [Update].
